Fuel Injectors - FirebirdV6.com/CamaroV6.com Message Board
Fuel Injectors
  • Fuel Injectors
    On a similar note to my cam install, ever since the cam install, my injectors have been really noisy... I listened with a stethescope and I'm sure the ticking sound is coming from them. I want to replace them with something quiet, because it almost makes my car sound like it's got an exhaust leak... which I do not have, I've checked every inch of it.
    So I was on Jeg's website and there are Accel injectors for sale, but only for V8 applications. I'm wondering if the LT1 used the same injectors as the 3.8 (will they fit) or what? They look the same from the picture.
    Does the 3.8 use 26 lb injectors or something smaller?
    Black \'97 Camaro RS <a href=\"http://chillcat.fortunecity.net/blahblah.html\" target=\"_blank\">See Pics</a> 3.8L, 5 Spd, Disc Rear, Hurst short shifter, MAF Screen Removed, RK Sport Headers, 3\" Cat, 3\" FM American Thunder Catback, Compcams .512/.507, (2x)275/40/17 Khumo 712(front) (2x)285/40/17 Good Year F1 GS-D3 (back).
    The 3.8 has 22lb/hr injectors.
    \'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
      i have LT1 24lb injectors in my car. they were from a 93 formula firebird
      96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
        intense-racing.com has injectors all the way up to 60 lbs. for the V6.
