kinda...I left all the rockers way loose so i can crank her with the starter to get the oil flowin' then I'll torque em down
I tried some Gen2 pushrods on my motor, and they are almost right. They are good enought to where I'm going to run them, but it seems they need to be about .010" longer.
I got .037" of lifter travel after zero lash. The Gen3's are closer to .050' (a little much) and .045" seems to be best in most cases.
The only drawback to using them is that at high lift/RPM situations, there won't be as much lift/duration -- BUT --- that's better than the pushrods being on the long side :P
thanks nightrider2. i have read alot about the 3500 swap, and i think i am going to stay with what i have and just add a bunch of bolt ons. i am actually looking for a set of headers that arent to overlly expensive. if you can lead me in the right direction i would greatly appreciate it. Thanks again.
thanks. can i order them offline, or do u know an individual selling them? i also heard that there was a stock cutout in the 3.4 manifold, and if taking that out, it woud give a 3 horses. is that true.
yes but if your going to take the time and spent the money......use 3400 stuff from a 00+ year car....theres no point in using crap
3400 stuff pre-'00 is good, it's only the 3100's that changed after '00 and became identical to the 3400's on the top ends (with the exception of the 3100/3400 written on the plenums).
I just read all 27 pages, my brain hurts! But I learned alot and will have many questions once I gather my thoughts!
im with oz on this one, 27 pages made my brain explode! there was alot of cross talk. (a little too much for my a.d.d.) it is good info though. it seems as if i need to take notes on this or just ask black or someone else who already did the swap to see what there thoughts are on the subject
