I had the tune sent in while I was installing the stuff. They tuned it to everything I told them I was installing.
every car is different... just sending them the pcm won't help they need something to go off of, like logs or a Wideband, dyno with wideband... something
www.turbov6camaro.com 1997 3800 Series II Camaro 4600 Stall for my ride to the mall :chug: 7.18 @ 99.77 1/8 -1.8x sixty (current quickest v6 fbod) 11.23 @ unk 5 1/4 - 7.19 1/8 - 1.83 sixty
My dad was so pissed he went straight to bed. I stayed up 'til 2 trying to research it. First thing that came to mind this morning was to check coolant/oil and the plugs. :)
So that's what happens when a plug wire is on the wrong terminal? ;)
Thanks anyway, guys..
Man that had to suck.. I rememeber when we first fired up my new motor and it wouldnt idle worth a crap with the intense PCM.. I was very scared... That is a very scary moment starting up a brand new motor..Well good luck with it!!
Jeff ..
1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
When I first started my car it idled nicely.
When I went to drive it, it misfired SEVERLY!
After double, then triple checking the plug wires, then installing new plug wires I found out that some of my spark plugs where somehow misfiring. They all looked great, but replacing them made it run great!
1997 Dodge Viper GTS
I built a 383 for my blazer and it was also my first build from the bare block up. I remember the first time I tried to crank it and my carb belched a ball of fire!!!! I had the dizzy 180 out I about crapped myself LOL. But after i fixed that problem she fired up and sounded sweet!! But then I heard a knocking sound and found out that you cant use a 350sbc oil pan on a 383 cause it will rub against it and sound like a rod knocking changed oil pan a Voila! Long story short Its the little things that will frustrate the HECK out of you.
\"I told you on your first day that I was your whole family, I am your new Mother! If you maggots don\'t start getting your sh_t together, I will be forced to make myself a childless Mother!\" <br />-Multiple Unknown USMC Drill Instuctors
