can anyone tell me if the 96 3.8 engine will fit in a 93 3.4?? if mods need to be done can someone please tell me what thank you
93 camaro
Re: 93 camaro
would the v8 swap be the same amount of work as the v6 3.8? if so do you think its worth it or should i just get a 3.4l to put back in the car? ... k-member is a brace under the car around the suspension/motor area right? thank you for your helpLast edited by Bartelbee; 04-24-2006, 10:04 PM.
Re: 93 camaro
It would probably be just as easy to swap a LT1 into that car as it would be to put in a 3.8. All depends on what you want out of the car really. A 3.4 would definately be easier.
Yes, the k-frame is the support under the engine.Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
