If you do port the heads, dont you port the intake bigger than exhaust?
I think there used to be a lengthy writeup about it/heads on the old server?
The writeup also said that Abbott heads were better in a way because
they have better intake/exhaust combinations that arent huge amounts of porting done.
thanks
i click on download, and basic, free download.
it wont let me
I try to sign up for an account, the place where it tells you to copy and type the letters into the form the form is broken.
thanks
Click Download. The next page says "Please scroll down for your download link." Down near the bottom it says "Download Now" with a link to the actual file.
You want to do it yourself? I wouldn't really suggest that unless you know what you're doing. Abbott and SSM didn't get to be good by just reading a book on it. ;)
i did my heads myself, when my head gasket went. all i did was get ride of all the ruff edges, and bumps, it was not to hard. just get a die grinder and some scrap metal, practice on the scrap till you are comfitable, and then try on your heads.
i did not notice anything, my car is mostly stock, all i have done is headers. im sure once i get a new air box and exost i will get more power out of the engine, to take advage of the ported heads.
Anybody can do it themselves. Just get a dremel and go at it. But grinding off a couple sharp corners is not going to give the results of a professional with years of experience with these very heads. It could easily make things worse. ;)
