I love the new cam/headers/tune. However, did it make my battery/brakes weaker?
Cam Installed... Battery/Brakes Weak?
Re: Cam Installed... Battery/Brakes Weak?
ur car is faster so it makes everything seem weaker lol2001 camaro a4 SOM vert <br />3800 series II <br />flowmasters american thunder <br />3.42 gears<br /><br />its not fast but i drive it like a natural beast
Well I was reading some book that said bigger cams tend to make the brake vacuum weaker and the brakes are a bit weaker.
Anyway, I was heading home and took the ramp on the e-way (getting off) and decided to floor it from 50 (my speedometer gauge is low because I had them calibrate it for 3.73s instead of wasting another $100 for it later). Soon it said 70 (probably around 80), then I nailed the brakes and they felt weak, but that's probably because I was going so fast and had so little time to stop.
The battery thing is true though. Last night my battery gauge kept dropping when I came to a stop and/or when I hit a dip in the road and all my lights would dim severely. Just coincidence?
The cam would lower your idle vacuum, which would make your brakes HARDER to apply slightly but not weaker.
Mine isn't noticable at all.
I have noticed slightly lower voltage levels since the cam.
In fact, if I stomp the brakes while sitting in neutral, you can see the gauge dip. I attribute it to lower VE at idle speeds, less power at idle, less vacuum etc.1997 Chevrolet Camaro v6 - 13.8@104MPH
1997 Dodge Viper GTS
Originally posted by NOS2006Well I was reading some book that said bigger cams tend to make the brake vacuum weaker and the brakes are a bit weaker.
Originally posted by NOS2006The battery thing is true though. Last night my battery gauge kept dropping when I came to a stop and/or when I hit a dip in the road and all my lights would dim severely. Just coincidence?Matt
1998 Mystic Teal Camaro M5
