do i need it and if not, how do i get rid of it. what can i expect from removing it?
balance shaft
balance shaft
96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHRTags: None
Re: balance shaft
lance said you dont need it. I want to just remove the chain for now.
I guess you would see a .1 increase in the 1/4 mile, as it weights 10lbs of moving weight, thats powertrain drag.2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: balance shaft
i dont know about .1 of but you will deff notice the motor will rev fasterwww.turbov6camaro.com
1997 3800 Series II Camaro
Re: balance shaft
Originally posted by NOS2006100 lbs = ~.1 sec in the 1/4, not 10 lbs.
10lbs of rotating mass also equals about .1 in the quarter.
As far as needing it if you remove it you will need to fill the oil hole in the block as well as having everything externally balanced to compensate for removing it, but for a hardcore build up it's something most will do!
Re: balance shaft
Re: balance shaft
Originally posted by NOS2006Oh, well the way he worded I thought he meant it was 10 lbs of rotating mass, equaling only 1 lb of static weight. That thing seriously weighs 10 lbs?!www.turbov6camaro.com
Re: balance shaft
As far as needing it if you remove it you will need to fill the oil hole in the block as well as having everything externally balanced to compensate for removing it, but for a hardcore build up it's something most will do!96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
Re: balance shaft
i did mean 10 lbs of rotating mass, which does not equal 1lb of static weight
its 8-10lbs of static rotating mass
I dont think you even have to worry about balancing. Lance said that he didnt really notice a difference with it on/off.2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: balance shaft
thanks for the input guys. one last thing. the hole that im going to have to plug, would i just be able to stick a freeze plug in there or weld something to the block or what? how do i plug it up.96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
Re: balance shaft
Originally posted by Timmythanks for the input guys. one last thing. the hole that im going to have to plug, would i just be able to stick a freeze plug in there or weld something to the block or what? how do i plug it up.
you can how ever just remove the gear and leave the shaft sit in the motorwww.turbov6camaro.com
Re: balance shaft
i said "remove the chain and leave the shaft"
viper is correct
i meant "remove the gear and leave the shaft"2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 weeks ago
