Hey guys what pound pressure of valve springs should I use. I ordered 90lb comp springs from ZZP with the rest of my valve train parts. A guy at ZZP siad 130lbs of pressure would be over kill and that 90lbs woud be better to bo with. Is that accurate or not. Thanx for the help guys.
valve spring pressure
01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
Tags: None
Re: valve spring pressure
Yea I was considering 105s. What cam are you using and what power gian did u get from it. Im gonna be using the Comp GT cam.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
Yep, I went with CompCam's GT2 camshaft.
I don't know the power gain I got, but at the same time I got 105s, oil-restricted pushrods (from ZZP), modified steel retainers (also from ZZP), ceramic-coated Pacesetter headers/y-pipe, a texas speed tune, 3.73s, and a LSD.
Then, 200 miles later, I coincidentally spun a rod.. but that's not because of the install of this other stuff. So I only drove my car with the mods for 200 miles before I couldn't drive it again. It'll be running again in about 10 days though! lol It's been like 3 weeks already.
I thought with the G2 cam ud need a Toque converor installed cuz its reccommended or whatever. If its not needed then I may exchange the GT for the G2 cam.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
Yea thats what I was thinking. Im gonna call them and see if I cna exchange the GT for the G2 cam if there wont be a restocking fee.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
