ATT all F-bodys. 3800 Adj. FPR install inside - FirebirdV6.com/CamaroV6.com Message Board
  • ATT all F-bodys. 3800 Adj. FPR install inside
    The ADJ FPR for the L67/FWD cars DOES NOT WORK..... so i looked around
    MSD PN2222
    Install time; 10-20 minutes
    Difficulty; Easy
    Tools needed; 4 clamps. screw driver. 1 foot of fuel line hose, 2 feet of small Vac line. 1 "T" vacum/boost fitting
    Fuel PSI guage.
    This is more for us high HP car with upgraded injecotors and fuel pump. this raise the fuel PSI on a 1:1 ratio with boost; and also lets you set your base FP higher.
    1. Cut the return line (the smaller of lines that connects to the fuel rail.)
    2. Put fuel line on and clamp it down, try to put 1-1.5 inches of rubber line over the solid stock line, install the FPR, side port to fuel rail and bottom port to tank.
    3. Connect up the vac line
    4. Start car and turn adjust screw to set your FP you want.
    5. check for leaks.
    6. test drive get in some boost and look at FP.
    7. stop and check for leaks again.
    You can probly get different line and hide it better. i'm goign to adjust mine in few days
    BTW i can take to the base FP up to 80 psi at idle
    www.turbov6camaro.com
    1997 3800 Series II Camaro
    Re: ATT all F-bodys. 3800 Adj. FPR install inside
    Jenn/Path ran an AFPR, however I am unsure ow what brand/model it was. Let us know how this one works out!
      best part is its only $55 form summit racing :)
