Engine knock after head install - FirebirdV6.com/CamaroV6.com Message Board
  • Engine knock after head install
    Well i put a set of heads on my car about a month and a half ago. Every thing was all good for about two weeks. then all of a sudden i noticed that why oil pressure was droping serverly while the car was ideling. under load was ok just at idel. Then a feww days later it developed a loud knock.
    So i took the heads of again and checked everything out. Everything was just fine. so i finished everything the other day and the car is still knockin and i dont know what to do. It sounds like there is something wrong with the oiling system, ie: oil pump . Any suggestion or any buddy know of any good shops in the chicago-land suburbs.
    please help me out.
    Too many mods to list! To see what I have done, check out my car domain website --&gt;<br /> <a href=\"http://www.cardomain.com/id/2k2firebird21\" target=\"_blank\">http://www.cardomain.com/id/2k2firebird21</a>
    Re: Engine knock after head install
    If the heads are still up, check all the pistons. Crank it over with a ratchet and when a piston is heading down, push on it and see if it budges.
    This was the problem with mine when I got a real loud knock. Pushed on the piston (cylinder 1) and it went down a little bit...
      Its probally not your top end, its mostlikely your number 2 rod bearing...
        Ouch, if it is, good luck. I haven't driven my car in a month because of rod bearing number 1.
          6 days ago
