94 3.4....B&M NEW VOLT COIL Power Unit - FirebirdV6.com/CamaroV6.com Message Board
  • 94 3.4....B&M NEW VOLT COIL Power Unit
    1) Can a B&M NEW VOLT COIL Power Unit work in a 94 3.4 camaro(coilpack)....
    2) And where is the positive side of the coil pack..?
    www.ftpp.net/v6ignition.htm
    The New Volt coil power unit is designed to produce increased spark intensity on inductive ignition systems. The New Volt is connected in series with the positive side of the coil, which means it will also work with coil packs or multiple coil systems. Since the ignition coil is the heart of the ignition system, increasing the voltage to the coil will vastly improve the spark performance with either a stock or aftermarket coil. It will deliver 20 volts to the coil even if the battery voltage is below 12 volts, making this ideal for racing without an alternator. The fully epoxy encapsulated electronics will provide trouble free life, even in the harshest environment
