Just wondering where the cam sensor is located and if this is a do-able job. Thanks.
cam sensor
Re: cam sensor
get yourself a Chilton's/Haynes ;)2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: cam sensor
it's easy enough. just go rent a harmonic bal. remover, remove your belt, put a screw driver up into your flywheel, and losen the bolt onthe crank,then the remover looks like a ducks foot, you will bolt that onto your pully, and take the pully off. then there is a plastic shield, take that off, and the sensor is right there and it's like 2 bolt. and then put it all back together. its about an hour job at most. oh make sure when your putting your pully back on your going to wack the he!l out of it so put a piece of wood in front of the pully, and smack that sucker on.
Re: cam sensor
Just get a Haynes manual.
Originally posted by kristenit's easy enough. just go rent a harmonic bal. remover, remove your belt, put a screw driver up into your flywheel, and losen the bolt onthe crank,then the remover looks like a ducks foot, you will bolt that onto your pully, and take the pully off. then there is a plastic shield, take that off, and the sensor is right there and it's like 2 bolt. and then put it all back together. its about an hour job at most. oh make sure when your putting your pully back on your going to wack the he!l out of it so put a piece of wood in front of the pully, and smack that sucker on.Originally posted by CHEVYINSIDEfront of the engine behind the crankshaft pulley i beleive
That's the CKP sensor, not the cam sensor. Cam sensor is much easier to change.Matt
1998 Mystic Teal Camaro M5
Re: cam sensor
Originally posted by trevor4425Just wondering where the cam sensor is located and if this is a do-able job. Thanks.
You should be able to change the sensor farily easily after you remove the drivebelt and perhaps the belt tensioner assy, too.
Re: cam sensor
Originally posted by Hib HalversonYou should be able to change the sensor farily easily after you remove the drivebelt and perhaps the belt tensioner assy, too.Matt
