ls1 swap - FirebirdV6.com/CamaroV6.com Message Board
ls1 swap
  • ls1 swap
    ok i know this has been talked about alot, but a good deal has come across my plate but i really don't think that i'm going to do it. just wondering what else i want to know what else i would would have to change this is what i have that would count
    3.73 GEARS
    POSI UNIT
    ALUMINUM DRIVE SHAFT
    HYPERTECH 160 DEG. THERMOSTAT
    EDELBROCK TORQUE ARM
    BMR LOWER CONTROL ARMS
    BMR PANHARD ROD
    BMR STRUT TOWER
    BILSTEIN SHOCKS
    WALBO FUEL PUMP SYSTEM (INTANK)
    could someone give me a line up of what i would have to get
    WAWA-A-HOLIC
    Re: ls1 swap
    get out traitor!!
    91 Mustang LX 2.3 Turbo - T5<br />-daily driver, 210hp/300ft-lbs (outdated)<br />94 Ranger Splash 2.3 Turbo - T5<br />-serious build up, shooting for 400+hp<br />95 Camaro 3.4 auto -hers<br />-she\'s workin on it
      Re: ls1 swap
      tranny
      PCM
      injectors
      radiator
      long block
      I dont really remember what all you would need.
      I dont really remember because I was just planning on getting a wrecked ss/z28 and swap it all out. Cant wait
        Re: ls1 swap
        k-member...
        There is more.... like the dash
        I want a LS2 soooooo bad out of a wrecked 06 vette or GTO or whatever!
        What all cars came with the LS2? Isnt it a 6.0 Ltr? Thats HUGE
          Re: ls1 swap
          Have fun paying for gas... and don't forget all the wire harnessing... ;)
          2004 CE Corvette 10.86@132mph
          2011 Cadillac CTS-V
          2006 Mitsubishi Eclipse GS
            Re: ls1 swap
            hey i'm not really doing it i was just wonderin. and i only get 12 mph now!! hehe
            WAWA-A-HOLIC
              Re: ls1 swap
              wow with the spray you still only do 12mph??
              but for real...12?!?!?!?! I get a little mad when I get 26 miles per gallon these days.
              The swap is expensive, I remember even if you get great deals on everything it'll still cost around $4k
                Re: ls1 swap
                http://www.tacreationsusa.com/3_4_3_8_v6_to_lt1.htm
                MrCoffee, I've said it before, I would spend a max of $2k on a wrecked Z28 and do the swap. http://car-part.com/
                  Re: ls1 swap
                  Engine, trans, pcm, engine harness, gauge cluster. Best if the pcm comes from a car with the same number of channels on the abs. (3-channel for non-TCS, 4 channel for TCS)
                  K-member, tranny cross-member, steering rack, steering coupler.
                  Radiator, rad hoses, heater hoses.
                  V8 fuel lines and the part that goes into the top of the tank. Or... '97 vette rail and fpr, and keep your lines.
                  V8 throttle cable. All the engine accessories (starter, p/s pump, water pump, alternator, a/c compressor, idler, tensioner). V8 maf, V8 throttle body, V8 lid. V8 exhaust parts.
                  Those are the main things.
                  Get some 12v switched power on the INJ2 circuit on the 3 fenderwell connectors, or one bank of coils and injectors will be dead.
                    Re: ls1 swap
                    not saying you cant do it that cheap, but if it were that easy to do it that cheap there'd be more people doing it. Most people contemplate FI or the swap since they're in the same price range
                      Re: ls1 swap
                      If you add the amount of work that needs to be done.. I just imagine All wiring.. Fuel lines out of wrecked car.. Turboing is hard but not that bad.
                        Re: ls1 swap
                        Somehow I had slipped dash wiring in my earlier post, but that's not right... In my '98 all I needed was the engine harness. The chassis harness and the dash harness was untouched.
                        Except for powering up the INJ2 circuit (which is not in the v6 chassis harness). I just pulled 12v off the rear o2 heater wire in the same bundle of wires, at the three fenderwell connectors. (I deleted the rear o2 sensors so I knew that feed wouldn't be overloaded.)
                        That was the only wiring thing I had to do on my swap.
                        I kept my fuel lines too, by using the vette rail. A rail mounted fpr (97 vette, and the v6 cars) rather than a tank mounted fpr (98+ LS1) is better in high hp applications anyway... :)
                          Re: ls1 swap
                          good info! THAnks!
                          the Tacreations.com website that I posted shows that little to no wiring needs to be done on my 2002.
                            Re: ls1 swap
                            And some of us try to do both... :D
                            And either one will cost more than you originally estimated too. Little things to finish it out, and additional supporting mods that are sometimes needed.
                              Re: ls1 swap
                              I would like to do both
