I'm about to start ordering parts to rebuild my valvetrain, and I was wondering if anybody is running the Comp 1.7 rocker arms with the GT1 cam. If so, what springs, retainers, etc. did you use?
Rocker/ Cam question
Re: Rocker/ Cam question
That would put your lifts to .5389 from .507 on the stock rockers.
CC 105# springs w/ steel retainers "should" support that amount of lift without a problem, however if you are ordering parts it won't hurt to just run the the CC 130# spring with modded or titanium retainers for not much more of a cost on the springs and modded retainers.
