i plan on adding the nessacery equipment for a 100 shot of spray. i plan on getting bigger injectors and the boost a pump. i was thinking about the injectors that are in the gtps stock. i have heard them rated at 33 and 36 lbs but either way i htink its enough to do. my question is will they fit, and if so would i need some tuning for them to work right. i have a mail order tune already so could i just get it retuned for them? thanks in advance, forrest.
injector swaping
Re: injector swaping
tune, yes
retune, yes they should, no charge
definately need bigger injectors2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
i think the gtps are 36ers but not sure, might want to ask in nitrous section2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
36 pound injectors are way too much for a 100 shot IMO. even with tuning your car will probibly run bad when not using the nitrous at low rpm's. I would try 24 pound injectors.
and on another note, are you running a dry shot or wet shot? if its a wet shot then leave your injectors alone.95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
with tuning you will be fine with GTP injectors na or on the juice. They are cheap and a good upgrade. 24# are sometimes not enough for our cars since we have 22# already. I plan on going with GTP injectors when I upgrade my motor.
are you using a dry shot?
3.8L does not have 22 pound injectors does it? I mean, hell the LT1's run 24 pound injectors, and they have 50% the displacement.95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
all years except 93-95 got 22 # lb injectors. (not speaking of 3rd gen, or 2nd gen, etc...) the 93-95 got 17 # lbs
check the technical database
I am maxing my stock 22 # lb injectors on an N/A 3.8L ( stock cam, stock heads, etc no major mods)2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Originally posted by AceYou guys forgot to mension that all the injectors are not interchangable. 2000+ doesnt use bosch style injectors.
dont forget about the impedance....2000+ use hi impedance, (puter communications)
