re-balancing the internal bottom-end - FirebirdV6.com/CamaroV6.com Message Board
  • re-balancing the internal bottom-end
    When getting your internal bottom-end stuff rebalanced what form should you have the engine in? Should it be
    Taken-off:
    cylinder heads
    oil pan
    timing cover,etc
    rear seal
    everything else
    Put back on:
    just crankshaft
    camshaft
    pistons/rings/rods
    (thats basically it, just a bare shortblock with the camshaft in it)
    Re: re-balancing the internal bottom-end
    all they need is the rotating assembly crank, rods, pistons, flywheel and damper.
    69 Camaro 350 4spd, Full Hotchkis susp, Baer brakes, moser 12 bolt, Flowmaster<br /><br />96 RS Hotchkis STB, subframe connectors, Hotchkis LCA and adj Panhard rod, SS camaro sway bars, Bilstein shocks, powerslot rotors, Borla exhaust, rksport headers, k@nFIPK
