new piston - FirebirdV6.com/CamaroV6.com Message Board
new piston
  • new piston
    I ordered a piston from my local chevy dealer.
    They said it was gonna be only the piston.
    Dont I need to get a shop to hook up the rod/arm/etc?
    thanks
    Re: new piston
    can I reuse the old connecting rod and assembly?
      Re: new piston
      The rods are bushed so you can swap everything out, they're not press fit.
        Re: new piston
        Just remember which way the old rod came out, meaning, which side was facing toward the front of the motor ... and double check the bearing surfaces ... made that mistake once .. :)
        \'97 Firebird 3.8 ... 1/4 mile = 12.50 (minutes)
          Re: new piston
          what was wrong with your bearings? what happened?
            Re: new piston
            his could have been stratched/ruined ect. just take a look at them, run your finger over them. if they're smooth your fine. if your worryed about it just post up a pic and we can tell you. how's your project going so far?
