well i know that 3.4 camaros are not at all fast. but is there any way to make the 4 gear a little more usefull i was raceing a mustang the other day and i had him the entire time. but that is when i noticed how worthless 4th gear is. it seemed like it just did not want to accelerate any more. if i put the z28 with the 3.42 rear would that inprove it at all???
4 gear sucks
Re: 4 gear sucks
changing your rear gears isnt gonna change your transmission gear ratios. You will accelerate faster through gears untill about 4th...4th gear is more of an overdriveJuiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
Re: 4 gear sucks
If you're racing fast enough to be in 4th gear you're probably at a dangerous speed- that said, the only way besides changing the ratio of 4th gear in the transmission is to add horsepower, that'll help it on top end. This probably should not be in advanced tech though.-Eric<br />2002 Navy Blue Camaro...Striped and Stalled. 35th Anniversary SS wheels <br />Best ET: 15.384 @ 88.32 on street tires<br />Project Whitney: Goal, 14.0 1/4 by summer 2008.
Re: 4 gear sucks
when you said 4th gear i automatically assumed you had a A4...hence the 4th gear being the last and final gearJuiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
