Hey guys the guy who tuned my car said Im almost at max with the stock injectors. So that if I do much else to the car that Id need to step up my injectors. What woudl be a decent pound of injectors to move up to.
nex step injectors
nex step injectors
01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
Tags: None
Re: nex step injectors
depends on what you have done to your car so far and what you plan on doing to it next'99 Camaro Y87 M5 T-tops
Flowmaster american thunder cat back, 2.5" magnaflow high flow cat, centerforce dual friction clutch
Car Domain
I jus did the cam with valve train and tuned. Im gettin redy to a MSD iginition box. Later next year im doing heads and intake.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
If you're not going power adder you could probably get away with 24# LT1 or 28.8# LS1 injectors, but since you have a way to tune it you can get cheap low mileage 36# GTP injectors and will be able to add even more fuel if you decide to do a power adder later on down the road!
