I forgot which cylinder the bent rod goes in. I'm retarded for not taking pictures before dissassembly! I didnt think I was gonna forget everything. Its been dissassembled for too long.
The rod is bent from the factory, correct?
thanks
ya, i now know that it really was bent. It happened because of a busted head gasket, it hydrolocked the cylinder. I dont know if it twisted/bent the crank. I have a new L36 rod on its way.
thats uh... pretty impressive. did that thing even RUN?!
