does anyone know torque specs on the lower intake manifold for a 98 camaro, my chiton book says 11 ftlbs for "intake manifold" I am not sure if this means upper and lower, thanks.
need torque specs.
Re: need torque specs.
On a 3.8
For "Intake Manifold Fasteners":
Lower manifold to head: 132 in/lbs
Upper intake vertical bolts: 132 in/lbs
Side bolts: 22 ft/lbs
NOW YOU NEED THE TORQUE SEQUENCE!!!2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
132 in/lbs = 11 ft/lbs (i would think the in/lbs scale is more accurate, correct?)
its Always good to work up in the torque sequence in 3 or more steps2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
are you serious? what do i look like?2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
I assume this is for a 2002?
Flywheel/driveplate to crank bolts:
step one: 132 in/lbs
step two: turn an additional 50 degrees2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
I also assume this is for a v6 auto:
convertor to flywheel: 46 ft /lbs
tranny to engine: 70 ft / lbs2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
