3.4 cam info - FirebirdV6.com/CamaroV6.com Message Board
3.4 cam info
  • 3.4 cam info
    Hi everyone Im new to this site so I will introduce my self. My name is Brandon I live in Pittsburgh, Pa and I own a 95 firebird with the 3.4. I am rebuilding the top en soon and am considering a cam swap. I found alot of cams that will fit. I was wondering what the biggest cam I can run with a stock computer? I plan on porting the heads myself not sure if I will use stock or switch to the newer alumiun. I have 19 lb injectors and I will port the stock intake manifold. I will run pacesetter headers and I have magna flow cat back installed tranny is stock 4l60-e with b&m shiftimprover. Thanks for the help:naughty:
    Re: 3.4 cam info
    Hey guys and girls I would really like so help on this I have looked every where but I havent foud any anwsers yet thanks
      Re: 3.4 cam info
      www.ftpp.net offers three cams that should work with the stock tune.
        Re: 3.4 cam info
        Hey, thanks for info, nut there is more than three cams on this site can I use any one? I already now that the crane powermax 2030 will work it is the old computer cam from crane, but can I go bigger with the speed density setup?
