find the weak link (mod list) - FirebirdV6.com/CamaroV6.com Message Board
  • find the weak link (mod list)
    Alright so if you don’t already know my project my goal is 500 HP ( which should be easily achievable), and we will worry about the quarter mile times after that. I already have most of the parts installed and am taking the car to ZZP for the turbo install and dyno tuning. Here is my mod list, I know the automatic weak link is the tranny, so any recommendations on transmissions? Also how is my rear end going to hold up to all this power, would I have to swap a 12 bolt? If anyone sees any other weak links in my project please let me know. It will remain stock bottom end as that should not be a problem judging from ZZP’s 9 sec. car on a stock L36 bottom end. So like I said give me some feedback if you see something missing.
    L32 GTP Short Block
    Msd blaster coils
    Nology Hot Wires
    NGK TR71X plugs
    Magnaflow 3” exhaust
    High flow cat
    65 lb injectors
    Stattama Stage 4 turbo cam
    Abbott Stage 3 heads and ported upper and lower intakes
    130lb valve spring
    Titanium retainers
    Oversived valves
    Cometic .065 MLS gaskets
    Meziere electric water pump
    Arp head studs
    1.7 comp cams pro mag roller rockers
    comp cams push rods
    160 degree drilled thermo
    double roller timing chain
    COMP OER lifters
    T/A Diff Cover
    SLP 85 MM MAF
    HP tuners.
    Innoavtive LC1 wideband with gauge.
    drilled and slotted rotors
    Edlebrock Tubular torque arm
    UMI panhard bar
    UMI LCA’s
    KYB AGX's
    subframe connectors
    sumituma HHR4 tires
    (track) weld pro star 15 x 8.5 MH slicks
    (track) weld pro star 15 x 3.5 skinnies
    Snow Performance Meth. Injection Kit
    HKS SSQV BOV
    Greddy Pro Spec-B boost controller
    FFF Forward Sweeping Turbo Headers
    Turbonetics T70 ceramic ball bearing turbo
    Turbonetics 42mm racegate
    Spearco intercooler
    Alumin. Drive shaft
    KYB 8 way adjustable shocks and struts
    B&M transmission pan
    Performabuilt level 2 transmission
    1le tranny mount
    Fuddle Racing 4000 stall
    Racetronix LT1 fuel pump kit
    greddy turbo timer
    Re: find the weak link (mod list)
    Originally posted by UDLOSE98
    BEING INSTALLED IN THE NEXT FEW WEEKS (ALREADY HAVE)
    Alumin. Drive shaft
    3750 stall
    Happy driver
    Fixed the list for you ;)
    1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
      haha, if everything holds together that is. and I will get instant dyno numbers too from ZZP.
        your rear end is gonna be crying with that much power and big stall. Might wanna start looking for a moser somewhere. Also is zzp making the piping for you? I live like 10 minutes from zzp and would love to stop in and check the car out. Let me know when you are gonna be there with it.
        http://www.bowtiev6.com/
          its an FFF kit but the piping needs to be modded to fit the pacesetters, I was told today the turbo is shipping out Tuesday ( i have been waiting for a month) so I will be there probably in 2 weeks. anyway could I upgrade my existing rear to better handle the power???? I do have Y 87.
            Viper has a 3800 Stall with 2.5TM. I think he might've broken a 10 bolt before? but he still uses a 10 bolt
              so a new diff cover for sure
                yea you could get a diff cover to strengthen it some, it depends on how you launch it though if it is gonna break or not. If you stall it up high and launch it like a beast you will be grenading it...if the turbo takes a bit to kick in and doesn't spool off the line so you are launching NA you will be ok for awhile
                  git sum NAWZZZZZZ!!!!!11!!!!!
                  haha. List looks good. Yeah I would definately look into a 12 bolt.
                  Maybe some weld-in subframe connectors too.
                    i can actually get a great deal on subframe's there is a local guy with a procharged SS, he is selling brand new connectors, he says he is too old for his camaro now, (he's like 23-24)?????
                      Weak links:
                      All the MSD ignition stuff. It will fail sooner or later.
                      10 Bolt.
                      They might make a few passes, but I wouldn't recommend long term use:
                      Pistons
                      Rods
                      Bearings
                      Which valve springs are you using? Retainers?
                      You have a link to this 9sec car?
                      1997 Dodge Viper GTS
                        yeah i broke the stock 10 bolt the eaton and ta cover seem to be holding up fine thus far
                        BTW you may find that stall is too small
                        the TR7 plugs will be WAY TO COLD
                        www.turbov6camaro.com
                        1997 3800 Series II Camaro
                          Pistons
                          Rods
                          Bearings
                          bottom will depend on the tune
                            I agree with you. But there is a reason forced induction factory cars come with beefy internals. Longevity.
                              I am gonna put some faith in the internals for now, What would be a good plug to go with for now?
