im rebuilding the top half of my 97 3.8l camaro and wanted to know what rockers i should put in and/or what cam. what all do i have to change if i do put a new cam in. thanks
new rockers and cam question
Re: new rockers and cam question
you will have to get new rocker arm bolts(gmpartsdirect.com is cheapest). You also might have to get a new timing chain. new water pump gasket. valve cover gaskets etc2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
1.7 i believe? not sure
what are the stockers?2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
dont wanna get valve float from too much lift2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Originally posted by Nachius1.6 is the only thing you can 100% say you can safely run with a cam.
Rockers raise valve lifts and the actual amount of lift is going to depend on the cam there isn't a generic number for it.
