I'm putting in a vs cam, new rockers, pushrods, lifters... I figure with 140k I should replace the timing set, but should I go with the single, or double? and should I get the JP, or the rollmaster from zzperformance??? the rollmaster double is more expensive than the JP... is the only diff the price???
also... I got this VS cam cheap from a friend, and was wondering, I know this is a fairly mild cam, will I notice much difference, or should I sell it and go for the gt2.
I also got 1.9 rockers from the same friend. Would I be better off not swapping the cam (to the VS) and going with the 1.9's, or do you think it's worth it??? suggestions...
