plans for a carbed 4th gen, thoughts? - FirebirdV6.com/CamaroV6.com Message Board
  • plans for a carbed 4th gen, thoughts?
    okay so in passing i started putting together some plans on how to put a carb motor in a 4th gen F body. if i am correct in my theroy the LT1 is an updated small block that shares its block dimensions with an older small block. in theory a sbc should fit into an LT1 era car. so i started doing some thinking and heres what i think youd need (tenetively):
    -350
    -T56 tranny
    -do away with car's PCM and use autometer gauges in custom dash plate
    -unhook ABS but power brakes will still work by hookin up vac line on new motor that went to power brakes on the old car
    -Hook up PCV and EGR on new motor to pass inspection (already on a motor we took out of my dads 78 camaro, and my state doesn't have emissions, just that you have the equipment)
    -current driveshaft should fit (aluminum)
    -new console
    -clutch/pedal assembly from a LT1 car
    -clutch
    -LT1 bellhousing or possible to use SB bellhousing
    thats all i can think of for right now... shoot me some ideas on what you think about this. it could be a totally screwed up idea with no hope of ever seeing the light of day. but i know i have seen pictures of a carbed 4th gen before.
    and i realize it wouldnt be the best choice for a motor, but itd be unique and still a V8, just build the motor a little before i put it in
    Re: plans for a carbed 4th gen, thoughts?
    you better check with your DMV, I know in some states it is illegal do swap a motor that is older than the car itself, i.e. if you had a 2000 camaro, you couldnt swap LT1 from say a 95.
      THere not toing to like seeing a carbed engine under your hood, if you acutlly have to pass a visual then Id say thats a no go.
      For power purposes, if you really set on a carb set up. Convert the LT1. Alot of guys do that. You can still make 500 hp N/A.
      1999 Pontiac Trans Am M6 Far from stock.....
        I've been throwing around the same ideas ... going old school carb in a fourth gen is possible, and has been done. I personally like it, but pretty much the motor and tranny will have to be replaced ... driveshaft probably won't fit, and the whole 'legal' issue I've been curious about. I found everything online to convert it, but the $$$$ is the big part. Either way, it would still be cheaper than going with a LT or LS and the buildup possibilities are endless for a SBC or BBC. Good luck and keep us (me) posted if you decide to do it.
        \'97 Firebird 3.8 ... 1/4 mile = 12.50 (minutes)
          You'd practically have to pull the motor out to get to the distributor cap! ;)
          Jason McCallister, Founder & Webmaster
          West Tennessee F-Body Association, Inc.
          2000 Camaro - Details
          Jason McCallister, Founder & Webmaster<br /><a href=\"http://www.wtfba.org\" target=\"_blank\">West Tennessee F-Body Association, Inc.</a><br /><br />2000 Camaro - <a href=\"http://www.wtfba.org/site/view_member.php?ID=68\" target=\"_blank\">Details</a>
            yea, that would really really REALLY suck
            I hate carbs and distributors anyways
              DUDE THAT IS A BADA** Idea...... i would love to see it.. if u are in the SC area i will help u... I am building a Turbo 4 barrel 350 right now... I would love to see the old school meet the new school.!!! run with it
              Read my liscenceplate Frame Corvettenet.com<br /><br />2000 Y87 Pewter A4<br />MODS:Tuned,3.73, SLP CAI, K&N offroad aircharger intake,Custom Plexi-glass Ram Air Box, Red Caliper ,Stage 2 Jet PCM, 3 inch Borla XR-1 Catback,ZR1 Rims Kuhmo 712s,MSD 8.5 SC wires
                im gonna go check with some inspection places tomorrow and ask them about getting that setup inspected. if it would pass in MO
                  there is a carbed intake manifold for the lt1 part no. 24502592.
                  96 camaro auto base model<br />slp cai<br />pacesetter headers<br />flowmaster catback<br />35th anniversary ss wheels<br />richmond 3.73<br />98+ ss spoiler<br />hypertech 160 degree thermostat<br />transgo shift kit
                    I have a buddy down here who is just finishing up his 99 Z28 project... Carbed 383 LS1. It's a pretty sick idea.
                    1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
                      I think someone on this board has done this before. It was a while ago though. They have a carb kit the the LS motors. That's the way I would go if I wanted the old school new school thing.
                      2002 SOM 35th Camaro. K&N filter, smooth intake bellow, 160* thermo, \'vette power servo, B&M transpak, Pacesetter Headers, 3in. in dual 2.5in. out Flowmaster 40 muffler, custom dual side exit exhaust before rear tires, MSD plug wires
                        just curious..why would u wanna do that? i heard that fuel injection engines are more effecient and out perform carbuerators in every way so i read in another thread on this site...
                          you are right
                          except for the "in every way" part
                          the only thing that carbs are better at is upper rpms which the LS1 already has alot of power at. But thats why you just get an LS6 intake (unless your LS1 already came with one which some did).
                          SFI is better for low rpm torque than carbs, better response, better gas mileage. I am not a fan of carbs at all.. they are kinda hard to tune (which is manually instead of electronically).
                            i already said why i want to do it, because i already have the motor laying around, and it wouldnt be something you see every day
                              sorry but people wont care if u see it everyday or not when they beat u with new age technology :)
