Pistons - FirebirdV6.com/CamaroV6.com Message Board
Pistons
  • Pistons
    Im planning on a 3400 upper swap, and Im just lookin for a good source to buy a set of pistons. Any suggestions?
    Re: Pistons
    you know you gotta pull the motor for pistons right?
    anyways www.ftpp.net
      Re: Pistons
      you're not serious are you?.......motor's already out, and Im lookin for 3400 pistons not 3.4 pistons.
        Re: Pistons
        most peole dont reffer to pistons as top end?
        anyways I am lost, they have pistons on that site for the 3.4 L engine.
          Re: Pistons
          I see where youre coming from.... Im swapping the top end but as far as I know I have to switch to the 3400 pistons to keep a safe CR. 3400 heads on a 3.4 makes like a 12:1 CR. That site carries 3.4 pistons not the 3400 pistons which carry a different CR. I also am in no need of fordged pistons, just looking for stock hyper pistons.
            Re: Pistons
            unless I am totally crazy, and stop me if i am 3400=3.4, cause I know for a FACT 3800 = 3.8
              Re: Pistons
              yes they are the same size motors, but the pistons in the 3400 (fwd) are different than the pistons in the 3.4 (rwd)
                Re: Pistons
                Totally got it now. what kind of car you drive?
                  Re: Pistons
                  really? learn something new everyday
                  I always just thought that 3800 or 3400 means it has a balance shaft.
                  I really wonder if I could put pistons in from the bottom of the block. (not taking off heads or pulling the engine at all). I want to be 1st to do it.
                  I sure as hell aint pulling my engine again..
                  If I were you I would search around message boards for 3400 pistons.
                    Re: Pistons
                    Not a car at all.....I have an s-10 that this is goin in. Planning on running it on megasquirt and boostin it. I already had the 3.4 in the truck with a tbi setup, but Im swapping on the 3400 stuff which is far better designed. Tried searching but all Im finding is links to fordged 3.4 stuff
                      Re: Pistons
                      Hijack: Slow, you can come up here to WI to try it on my car, lol. I am thinking im gonna have to pull it now.
                        Re: Pistons
                        Please tell me you're joking ??? Or do you plan on pulling the tranny insted ??
                        \'97 Firebird 3.8 ... 1/4 mile = 12.50 (minutes)
                          Re: Pistons
                          leave the tranny in
                          just drop the oil pan, crank and possibly the cam
                          I saw that it might (big MIGHT) be possible
                          I want to be the first to change bottom end with the engine in the car.
                          Serious as cancer
                          why because you are thinking of upgrading your bottom end?
                            Re: Pistons
                            I guess it's possible ... but good luck getting the crank and flywheel out with the tranny still hooked up. And, that crossmember's gonna be a %^&* ... You're a bigger man than me to try it. I'd just pull the motor and make life a whole lot easier.
                              Re: Pistons
                              why because you are thinking of upgrading your bottom end?[/QUOTE]
                              I dont think I really have much of a choice. I am pretty sure I will snap my rods like toothpicks. But I have never pulled a motor before, and I know my way around the top end, but not so much the bottom end.
