LS1 t56 swap? - FirebirdV6.com/CamaroV6.com Message Board
LS1 t56 swap?
  • LS1 t56 swap?
    ok i was just wondering on how hard it would be to do a ls1 t56 swap in to my 98 3.8 auto car? i know some mounts might be diff and that car must be lifted off and onto the motor. any help/insight is apreciated:)
    Re: LS1 t56 swap?
    ok go here and all your q's will be answered
    http://www.dxsoftware.com/magnus/
      Re: LS1 t56 swap?
      Do you mean an LS1 engine and T-56 transmission swap or figuring out a way to mate a T-56 transmission to a 3.8 motor?
      2001 Black Z28 M6<br />Sprayed, slotted, geared and more~
        Re: LS1 t56 swap?
        by mounts i think he means ls1
        but good point
          Re: LS1 t56 swap?
          It would essentially be the same as the auto LS1 swap, like in that link, but...
          You would need a clutch pedal assembly, master cyl, hydraulics, etc.
          And you would need a manual style center console.
          1997 Dodge Viper GTS
            Re: LS1 t56 swap?
            It's also a LOT easier if you stick to a 98 LS1 setup. A lot of stuff (wiring) hooks straight up instead of having to switch them over for a new year. You'll also need to run a wire from the fuse box to the passenger side fuel injectors harness or all cylinders will not fire.
            1998 Firebird w/ LS1 & A Few Mods<br /><br />Pictures--&gt;<a href=\"http://www.fad2blk.smugmug.com\" target=\"_blank\">www.fad2blk.smugmug.com</a>
              Re: LS1 t56 swap?
              i did some research and like FAD2BLK said it would be much easier for me to do i found all kinds of charts and everyhitng to help me out some too. i have found a few ls1/auto combos on ebay with about 35000miles on them for around $2500. however this project will not start till i get my T/A done and then it may still be a year or two from now till i really get serious in doing it but i want to get as much feedback/info before i start. thanks for all thehelp so far keep it coming
                Re: LS1 t56 swap?
                I have done this exact swap and went through tacreationsusa.com for all my parts. They are by far the best company I've ever done business with. Good luck.
                  Re: LS1 t56 swap?
                  thanks a lot man i checked out your site and you did a very nice job on your swap! about how much did you invest and how long did it take?
                    Re: LS1 t56 swap?
                    All together it was around 6k for motor/tranny and a few mods at the time of the swap.
                      Re: LS1 t56 swap?
                      thats not that bad realy. i know ive been looking and i found a ls1 auto combo on ebay with 35k on it for about 2500 and handfuls of othere ls1's under 3k
