New Rebuild, no OIL psi! - FirebirdV6.com/CamaroV6.com Message Board
  • New Rebuild, no OIL psi!
    I just rebuilt my engine as we all know.
    I'm cranking it over (yes with the starter)
    and its not building ANY oil pressure!
    The dash gauge reads close to zero!
    I kinda smashed up the filter when I installed the engine.
    Maybe I should try a new filter.
    Re: New Rebuild, no OIL psi!
    yes you should. I do believe we recommended you do so and i thought you said you would. There should be a bypass valve i believe and I'm not really sure you are going to get pressure readings when cranking.
    2000 3.8 A4 Pewter Camaro
      Ok, I will change the filter, but there is gonna be like an Exxon Valdez oil spill all over my city
        whoa, I was just sitting here cranking, then letting it cool, repeat
        all the sudden the oil psi jumps to about 55psi
          then the oil psi dived back down to 1 or 2 psi BEFORE I changed the filter
          I've got a new filter on it and its still at 2psi
          Maybe it caught a glimpse of some petroleum jelly or assembly lube heh ;)
            is your oil pressure switch bad? hook up a manual gauge dont rely on the dash gauge. especially on a new engine.
            '99 Camaro Y87 M5 T-tops
            Flowmaster american thunder cat back, 2.5" magnaflow high flow cat, centerforce dual friction clutch
            Car Domain
              oil pressure switch? lol
              its the stock oil pressure sender/pump
              the one that is built into the timing cover
              that manually pumps oil when the crank is going.
              I dont think I'm gonna really get much pressure just cranking
                the reason I hadnt switched out the smash filter before is some people said I could try and use the smashed one to prime the pump (since it had oil, pre-assembly lube and petroleum jelly in it)
                  do you have an electric pump or something?
                    you sure do talk to yourself a lot on here
                      so what are you trying to say?
                        wanna make something of it?
                          lol he's "here to stay", so if he wants to postwhore its ok. he's not artificially inflating his status haha. like family guy "wanna fight about it?"
                            where he fights the chicken salesman?
                              now i know how people get thousands of posts.. haha
                              1996 Chevrolet Camaro
                              1995 Buick Park Avenue Ultra
                              --Appearance Moderator--
