Hello first post here:). Last week my oil filter gasket cracked and all the oil in my motor (98 3.8) was sprayed all over the engine bay while I was driving. Didn't know anything was wrong until I noticed my oil pressure was at zero and at a that point I was 100 yards from my house so I just drove the rest of the way. Just as I'm pulling in my driveway the engine dies and I cost that last 10 feet. I pop the hood an see the oil everywhere. Cleaned everything up and start to change the oil and thats when I noticed the filter crack. With new oil and new filter in the car, I was crossing my fingers that no damage was done....I was wrong. I start her up and I hear a CLACK CLACK CLACK sound from what seemed like one cyl. Right away I knew it was a bearing.
I spent a hell of a day (18 hours) pulling the motor and tranny as one unit out the top......DON"T EVER PULL BOTH AT THE SAME TIME FROM THE TOP. It was hell dancing that cow out of the engine bay with so little room. Anyway I get the motor out and I'm checking the connecting rods for play and come across one that has no play. and sure enough the bearing had spun a full 1/4 turn. The bearing is all cut up and with gashes and many of the other bearing, while still in place, do show some burn marks so the whole lot has to go. The journals look good as new so no damage there.
Now to my question. Do I need to use oversized bearings for my car with 90K miles or will standard size work? I'm not sure at what point I need thicker bearings, if its after X-number of miles or after market rods. Could someone please fill me in on the rules for bearing sizes. Thanks a lot for your help.
Here is a pic......
Here is a pic......
