I'm doing a head gasket replacement and this is where I am stuck at. I pretty much got everything off except for the Lower Intake Manifolds, heads, and passenger side valve cover. I just can't get the bolts behind the motor loose since I can't fit my breaker bar back there. I'm talking about the ignition module bracket, and motor lifting mount thing thats blocking one of the valve cover bolts. Anybody have any good tips or tricks?
Whats a good way to break bolts loose behind the motor?
Re: Whats a good way to break bolts loose behind the motor?
Oh man, you are at teh best part, I hope you have taken off the negine removal bracket on the pass side in the back, if not, OOOHHHH MAN!!!! get some racheting wrenched and plan on an hour or two.
Originally posted by UDLOSE98Oh man, you are at teh best part, I hope you have taken off the negine removal bracket on the pass side in the back, if not, OOOHHHH MAN!!!! get some racheting wrenched and plan on an hour or two.1997 Camaro Y87. Turbo.<br /><a href=\"http://pureoctaneracing.net/\" target=\"_blank\">Pure Octane Racing</a>
