how hard is it to relocate an engine mount on an engine
hmmmmm???
Re: hmmmmm???
OK...I'll respond.
If your thinking of locating the mount in a different location on the side of the block, then drilling some holes into the block to bolt the mount to.....Forget it. You will compromise the engine/block structure.
If you fabricate an offset adaptor that bolts on the original mount attachment on the side of the block and then allows the mount to be bolted to the adaptor but not in line with the original attachment to the block.....Yup, you can do. Been done many times before.
Also, you can fabricate a plate that has overhangs that when bolted to the front of the block allow the mounts to be bolted to. The shape of the plate depends on where your mounts need to be to pick up on the car's frame.Now Playing: \'99 Pewter Firebird, stock, bone stock, and nothing but stock, so help me God!<br />Comming attractions: K&N Filter, Lid Mod, Intake Bellows Smooth Pipe Mod.<br />I dream about: Forced Induction (TC or SC) or NOX (or both!)
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....3 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.3 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
