hey guys. just getting stuff around for this shortblock and wanting to know if any of you have built a 3.8 short block/ blance shaft? did you need any tools that are just for that motor from GM. also any other tips that you may know of that would help me out along the way... thanks guys
shortblock
Re: shortblock
if you are building a shortblock up, ditch the balance shaft. Extra weight removed then
Re: shortblock
dont mix anything up.
document everything for real!
have a nice clean area to lay everything out (so you can remember how it goes back in!!!!!!!!!!!!!!!!!!!! QFT!!!! )
removing the balance shaft isnt that hard unless you completely remove it
yes i rebuilt mine and removed the B/S2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: shortblock
its just there to reduce vibrations, it will vibrate a little bit more but not really noticeable unless you are trying to feel them. You can take just the gear out and leave the bs in there or remove it and then you have to do some work to the oil holes
Re: shortblock
you dont have to do anything to get it to run right
if you completely take it out.. you have to plug up some oil holes
if you just remove the balance shaft gear, then its good 2 go i think2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: shortblock
ok yea the block i got to work with allready had the b/s out of it... so i am starting with a bare block. what you do if you were me ? is there any pics/witeup's on this b/s removel ?Last edited by bigblock10; 10-26-2006, 03:22 PM.
Re: shortblock
right if you just remove the gear you can stop there.
If you want to remove the shaft entirly, you need to plug the two holes, that was I was trying to get at with my first question, but i was beat to the punch.
Re: shortblock
Originally posted by UDLOSE98If you want to remove the shaft entirly, you need to plug the two holes, that was I was trying to get at with my first question, but i was beat to the punch.
lemme get a writeup2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: shortblock
Originally posted by slow6actually, dan the man, there are 4 holes to plug, its easy
lemme get a writeup
BTW where have you been the past few nights, pussin out before 5 am?
Re: shortblock
nah, sorrry, i been partyin and hangin out elsewhere2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
