well i've decided to switch from a 3.4 to.........a 4.3...thats right...biger engine...same numbers, anyway does anyone know tricks or important thing about these engines that could help
the big swap!!!
Re: the big swap!!!
Lets start with what you know. Please post everything you already know. Then we'll fill in the gaps.00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
Re: the big swap!!!
:work: why go to the 4.3???? That doesn't make much sense money and workwise, either 3.8l or v8 that thing and it will be easier and possibly cheaper for ya.Last edited by 97rs4life; 10-30-2006, 04:09 PM.
Re: the big swap!!!
he is probaly thinking about funding.....it is probaly alot cheaper... what kind of power does the 4.3 have.. if it is close to the same then it does not make any sence. i am stuck on a little fence myself right now... i was thinking of building a lt1 and slaming it in my car.. or a 383 stroke... i have not decieded yet.. ahh screw it were is the nearest 572 lol....
Re: the big swap!!!
Swapping the PCM is going to be a big PITA I would think. Would the stock K-member work for the 4.3? Probably need custom exhaust, well Y-pipe anyhow. Will the 4.3 fit up to the tranny of an fbody? Lots of varialbles to think about...
I'd go with a 3.8 or V8, probably cheaper and more mods are available for them than there are the 4.3. Guys who mod mini trucks swap the 4.3 for carbed 350's with no computer. The 4.3 is built for low-end torque, the top end power sucks.sigpic
1997 Camaro RS A4
2006 Chevy Colorado
2003 Kawasaki Ninja ZX6-R
Re: the big swap!!!
Originally posted by ShodownSwapping the PCM is going to be a big PITA I would think. Would the stock K-member work for the 4.3? Probably need custom exhaust, well Y-pipe anyhow. Will the 4.3 fit up to the tranny of an fbody? Lots of varialbles to think about...
the transmission is compatible with the 4L60E if its a vortec 4.3L off a s10 or sonoma. i agree tho, good low end power none up top.
'95 3.8L A4 PGM. & '95 LT1 M6 PGM. :burn:
Re: the big swap!!!
Originally posted by gugdathug3the transmission is compatible with the 4L60E if its a vortec 4.3L off a s10 or sonoma. i agree tho, good low end power none up top.
and you will need a lt1 front crossmember or the 4.3 wont fit(the 4th gen v8 crossmember sit lower)
the 96 and newer heads flow great and would make good power with a cam and lightweight 9.5 cr pistonsWolf<br /><a href=\"http://www.cardomain.com/memberpage/249111/7\" target=\"_blank\">95 black t-top camaro</a>,3.4 5 speed,ud pullies,plugs/wires,de-shaft tb & gutted airbox, homemaid short throw shifter
Re: the big swap!!!
heres the mounts you'd need to put a 4.3 in
http://www.allstarperformance.com/product.htm?prod=334Wolf<br /><a href=\"http://www.cardomain.com/memberpage/249111/7\" target=\"_blank\">95 black t-top camaro</a>,3.4 5 speed,ud pullies,plugs/wires,de-shaft tb & gutted airbox, homemaid short throw shifter
Re: the big swap!!!
ok i missed alot here ...
1) one of my buddies buddies wrecked his jimmy and wants 500 for the motor
2)i work at advance auto=sweet discount and access to uber info
3)mines a t-5 manual so it should bolt up...being it was used in a s10
i've got the swap figured out...i just want info on things like heads, intake, cams,...o and its a vortech with 80,000 on it...so it'll go forever
Re: the big swap!!!
i've got the swap figured out...i just want info on things like heads, intake, cams,...o and its a vortech with 80,000 on it...so it'll go forever92 S10 3800 A4(96)<br />1/4: 14.374 @ 92.25 w/ 1.976 60\'<br />Turbo and 12\'s Coming Soon!
Re: the big swap!!!
true.... i own a '99 sonoma with 220k miles.
good luck with the swap!
