It may seem a bit on the steep side, but I am thinking of going NA and looking for 12s or at least very low 13s. What I plan on doing is a stroker kit (Possibly the ZZP, but looking into more options, comeracing.com may be a stretch), a very high lift cam, some ported and polished heads, diamond pistons, bored .20 over or maybe .30, p&p upper and lower intakes, all neccesary bolts and studs, correct rods for the stroker kit, tuning gears injectors etc...
Only things I am unsure of are rocker sizes to go with the GT3 cam, exact injector size (I'm guessing 30# or so) and spring pressure to run 6500-7000RPM. I'm also a bit on the fence about actually stroking the motor.
My current best ET is 14.9@94 on a 2.1 60' on my winter tires/steelies. (205/70R15). I've since done better on my 255s but I am unsure how accurate those GTECH PRO SS's are. I've gotten consistant 14.4@95 with a 1.9 60' time. All I have done currently is an aluminum flywheel, stage 3 clutch and a custom catback with a racing cat with other odds and ends such as deleted EGR (It rusted apart), deleted MAF screen, cone filter in place of the airbox and removed spare tire/jack.
So I just want some opinions on what else to do. I also do have a 2.75" I-pipe off a Z28 to replace my 2.5" pipe and some pacesetter coated headers going on the new motor. I don't know if I am really going to need 3" exhaust, even if so the 2.75" should suffice until I get it.
Anyway, Another idea I have is an L67 or L32 bottom end mated to a nice big cam, my ported and polished heads, ported upper and lower intakes and everything else, forced induction of course. Procharger maybe? Turbo seems cool too, but seems a bit harder to pull off and definitely pricey.
