I want to replace the fuel injectors on my 3.4liter. What is the right size that would give me a little more power?
Fuel Injectors
Re: Fuel Injectors
what is the reason for replacing them? Is one bad?
When you go to a bigger injector you need a way to tune for it or you are going to be running rich. I would stick to stock size unless you are doing a turbo build or something
Re: Fuel Injectors
To make use of the added fuel, you have to have to be pulling in more air...so just placing the injectors without doing any other mods isn't going to net any gains. If anything, it'll just make you run rich and hurt your MPG...and if you tune your computer for the larger injectors, it's still gonna run exactly the same.
