ok where should i go - FirebirdV6.com/CamaroV6.com Message Board
  • ok where should i go
    i have a 98 camaro and i need rods,crank,pistons should i get a stroker kit?
    where should i go? i also want to spray it when it gets back out so ant suggestions?
    1998 camaro \"all slow no go\"<br />SpeedComp burlington nc<br /><a href=\"http://www.myspace.com/2supafly\" target=\"_blank\">www.myspace.com/2supafly</a><br /><a href=\"http://www.triadfbody.com\" target=\"_blank\">www.triadfbody.com</a><br /><a href=\"http://www.carolinafbodyclub.com\" target=\"_blank\">www.carolinafbodyclub.com</a><br /><a href=\"http://www.cardomain.com/id/esr98rs\" target=\"_blank\">http://www.cardomain.com/id/esr98rs</a>
    Re: ok where should i go
    junk yard for all that (except stroker)
    "should I get a stroker kit" ?
    that is completely up to you
    but my answer is duh
      hmmm those seem like pretty scattered questions.
      are you looking for OEM replacements?
        is it going to be a Daily Driver?
        do you want to spray alot or a little?
        how far do you plan on taking it?
        ....all kinds of information we need to know (dont be Vague, we're not mind readers) ;)
        BTW, I doubt you could spray the stroker kit, unless it was a very small shot
          sorry about the question, im just lost on what i need to do..my car was started with no oil and i dont know where i need to go to get everything fixed.. looking at my options too. my crank, 4 rods, and all my bearings are screwed and im not sure what i should do. i need new rings too.. where should i go to get a rebuild kit? maybe like auto zone or does someone know a better place. i have a hard time finding stuff for this motor
            yea its a daily driver. i have a Nos kit for the car snd i want to spray it a lil bit...just to give it a lil pep
              yea, they dont recommend more than 9lbs of boost or a 50 shot on the stroker
              dont go to autozone! ugh
              Total Seal piston rings and AE Clevite 77 Trimetal bearings
              Is your block okay???????????????????????????
              you could just get a junkyard motor..drop it in and be done with it
              (unless you are wanting to build up the motor)
                well it has a cam, new springs pushrods timingchain retainers valveseals... i can get a motor for like 500 bucks,my motor is @ a machine shop...i dont think im going to the the stroker kit..
                  Depending on how much you're intentions are with the spray, there's two stroker kits available to you...
                  The first can handle a fair amount and the second will handle quite a bit.
                  We just want to be safe with the tune...
                  Good Luck whatever direction you head.:tup:
                    yeah $500 for a new (used) motor sounds OK.. might get lucky and get something with about 60-70K on it.. I always say a new motor is the way to go as you can always save all of your old cutom stuff and put it in later and + with a full reubuild there is always something that pops up and always something else you end up needing and the price ends up adding up.. $100 for gaskets then couple $100 for the machining then $100 for this that and the other... geuss the real question is how much time do you have and what did your old engine have on it?? if you had soemthing with like 40K on it then you've got to do some thinking.. but if you have something with like 150K on it if so then its a no branier
                    good luck
                      I will Never buy a stroker... just too much $$$
                      You spin a bearing and its probably gone for good
                      Then you're probably gonna need a new block and new stroker crank
                      My $$$ goes towards FI or N20
