injectors installation - FirebirdV6.com/CamaroV6.com Message Board
  • injectors installation
    I did a good amount of searching and I noticed that we don't have anything on injector installation.
    I have a 2001 camaro and I was wondering if anyone knows where I can find information on what injectors I can use (looking for something around 36lb) and how to install them.
    I have dug up information that tells me I can't use the Bosch style injectors (is that what GTPs use?).
    I have HPTuners and there's already more than enough information out there to tune for the bigger injectors.
    How hard is it to get to the injectors compared to a spark plug change?
    I'm still looking around - if I find the info I'm looking for, I'll post it here for others.
    Re: injectors installation
    Pretty much install new O rings on the injectors, "snap" them onto your fuel rail, and bolt the fuel rail down. As far as the correct injectors and wiring harness type, I am not sure, BLLDOG would probably know.
      put some grease around the o-rings as well.
      I have no idea what other injectors you can use, information like that is not accessible to technicians. that is strictly aftermarket/modification stuff....not condoned by my people.
      2000 3.8 A4 Pewter Camaro
        you can look around...alot of the name-brand companies make something that your car can use; basically, any injector LS1's can use, so can your car. Installing them is a breeze...just un-bolt the fuel rail and a few other things ontop of it (coil pack, alternator if you want easier access) and lift.
          Bob, if you need it, I made a write up last summer on how to remove your fuel rail and injectors. If you want it, drop me an email and I will send it to you. :)
          1997 Camaro RS A4
          2006 Chevy Colorado
          2003 Kawasaki Ninja ZX6-R
            i don't think you're gonna find 36lb multec injectors. You're gonna have to switch to bosch. Try this:
            http://www.fullthrottlev6.com/forums...ltec+injectors
              :banana: that would be awesome.
              is it something we can link to or post here for others?
              if its a web hosting issue, i can help with that.
              THANKS!:tup:
