for those running LS1 MAF - FirebirdV6.com/CamaroV6.com Message Board
  • for those running LS1 MAF
    ...just stumbled across and picked up this from ZZP today, pretty cool, check it out
    http://www.zzperformance.com/grand_p...=603&catid=108
    Re: for those running LS1 MAF
    So, you are up and running?
      there would b a huge thread if that thing was up and running....DURRRR
      87 Firebird RIP
      96 Camaro RS RIP
      94 Patriot Red 1LE Z28 - Sold
      02 WS6 TA - Sold
        How good is the LS1?
        I've read about the 2-bar gp maps
        at least your problem has been figured out yeay!
          there is a guy by the name of usd2sing who doesn't go on this site that runs the vette MAF with the IAT sensor built in. He plugged his TB and put the new MAF inline in front of the tb. Works just fine using that 3-5 wire connector from zzp....however I think you are still going to have issues maxing that out.
          Andrew is working on a lt1 maf and seeing if it will let him run more air though.
          http://www.bowtiev6.com/
            Originally posted by slow6
            If that is directed at me.....?
            Travis you know I know dan (usd2sing) and I know of his LS6 maf for n20.
            If you read my thread over there?
            no this was for UDLOSE98 to know that it has been done and the wire adapter works great
              i have heard issues of outflowing it....guess i'll just have to wait and see
                yea the ls1 doesn't flow as much as the lt1 maf, they are both being maxed though
                  So, is there any gain to switching to a LT1 or LS1 MAF? I've got one I can get if it is :D
                  ~97 3.8L V6 Camaro~
                  A few things
                  Only Member of Team Hooker?!?
                    not really, not for an N/A application
                      It's for the guys running power adders and maxing the stocker out. No gains really from switching it NA. Main problem is the computer tuning ability holding it all back unless they trick the pcm into thinking it has different sized injectors in there and tweaking the maf table then.
