SpeedingFirebird I have a ???? - FirebirdV6.com/CamaroV6.com Message Board
  • SpeedingFirebird I have a ????
    Hey i was thinking about getting a cam that has the same specs as your's but i have some ?'s first..
    CompCams Hydraulic Flat Tappet Camshaft
    1993-1995 3.4L V6
    Duration (Intake/Exhaust): 212°/212° @ .050"
    Valve Lift (w/1.5 Rocker): .440"/.440"
    Lobe Sep. Angle: 110°
    1.Did you need a tune for the cams choice you selected
    2.How much Hp did this cam help you and how much did it helo on ur e/t time guesstimating if you dont know..
    3 would you reccomend this cam to anyone else or would you say more aggressive...
    4. do you have any video's of you car with the cam..
    thanks if you get this...
    also would i need a tune for this cam?
    CompCams Hydraulic Flat Tappet Camshaft - CUSTOM GRIND
    1993-1995 3.4L V6
    Duration (Intake/Exhaust): 226°/236° @ .050"
    Valve Lift (w/1.5 Rocker): .463"/.474"
    Lobe Sep. Angle: 112°
