valve springs - FirebirdV6.com/CamaroV6.com Message Board
valve springs
  • valve springs
    ok i have decided to start my motor mods with some 1.8:1 rockers but i say to myself why not upgrade springs and rods as well right. well i have a question how do you keep the valves from falling down into the cylinder after you have taken off the springs? i have ideas on how to do it and more than likely one is corect but i would like to ask you guys how you all did yours. all sugestions would help and thanks for your time.
    Re: valve springs
    use an air compressor to hold the valve in place until you can wrap a rubberband around it. there's also a way of inserting string into the chamber until it holds up the valve.
      Re: valve springs
      insert string, rotate the piston until it compresses the string in the cylinder
