Hell yea...8lb flywheel that will fit the 3.4. Because the 2.8 and 3.4 and basicly the same minus bore and stroke this will fit. Summit = God!!
Damn. Good find man.
1995 Bluish green 3.4l Camaro.<br />Bone stock right now lol!<br /><a href=\"http://www.cardomain.com/ride/2042355\" target=\"_blank\">http://www.cardomain.com/ride/2042355</a>
auto's dont have flywheels, they have flex-plates. manual's have flywheels, and yes all it does is let more power get to the ground.
um. just be careful - the fact that the flywheel is 2 inches shorter will mean that the clutch slave cylinder will sit out farther ( the rod that touches the fork) and the clutch pedal will feel softer - the closer the flywheel edge / clutch is to the clutch fork, the stiffer the pedal will feel (ive been through this when i had my flywheel resurfaced).
there is actually a resurfacing limit for the 1993-1995 fbodies and manual transmissions. i would double-check and make sure the thickness wont bother anything before you bolt it up and cant get the tranny out of gear.
just a suggestion tho
good luck w/ that, let us all know if it works.
Originally posted by Driver_10
I intend on using an adjustable Mcleod hyrdo release berring. They make a direct bolt on that fits my TKO600 Tranny. The flywheel does have a slightly smaller ring-gear so it will require the use of a 3.1l style starter. (I didnt notice it the first time)
Since I have a 3400 block and a driver side starter boss on my flywheel, this wont be a biggy for me.
Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...
