does any one know if u can take the crank out of the 3.1 and put it into the 2.8?
stroking 2.8 v6
Re: stroking 2.8 v6
I imagine it would work. Dunno if the 3.1 and 2.8 blocks are the same (RWD to FWD that is).
They have the same bore though. Might as well get a 3.4L though cause it wouldn't take much more and the 3.4L is a bored and stroked 2.8L that is RWD. You can pick up a long block for less than $100 at most salvage yards.2005 Ford Focus ZX3 SE D20 M5 - Modified ;) <a href=\"http://www.knightenmotorsports.com\" target=\"_blank\">http://www.knightenmotorsports.com</a> <br />[ U R L = h t t p : / / w w w . g e o c i t i e s . c o m / h e a r t l a n d _ h e a t _ v 6 ] Heartland Heat V6 [ / U R L ]
Re: stroking 2.8 v6
Originally posted by speedracer95v6I imagine it would work. Dunno if the 3.1 and 2.8 blocks are the same (RWD to FWD that is).
Re: stroking 2.8 v6
D'oh! I was thinking 3100 engine.2005 Ford Focus ZX3 SE D20 M5 - Modified ;) <a href=\"http://www.knightenmotorsports.com\" target=\"_blank\">http://www.knightenmotorsports.com</a> <br />[ U R L = h t t p : / / w w w . g e o c i t i e s . c o m / h e a r t l a n d _ h e a t _ v 6 ] Heartland Heat V6 [ / U R L ]
Re: stroking 2.8 v6
also what would be the right piston size for the 2.8 i was gonna buy some new ones but they have like 4 diffrent sizes and i dont know witch one is the right size and do they come stock with flat tops or the vavle cut out kind?
Re: stroking 2.8 v6
from my understanding, the 2.8's (or at least some of them) had the smaller journal diameters. This tended to make them a bit weaker than the 3.1 and 3.4 cranks.
I am wondering, why are you looking to build a 2.8? a 3.4 would almost certainly fit where the 2.8 currently sits, and since they are all practically the same engine and have many interchangable parts, why not just use the 3.4? Hell, slap on some AL heads and intatke from a 3400 FWD engine, install the dished FWD pistons, and you are good to go.Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
Re: stroking 2.8 v6
Originally posted by camaroman1181I am wondering, why are you looking to build a 2.8?
edit: did u say the front wheel drive 3400 have aluminum heads?? what model cars did thos motors coem in?Last edited by L0tuS; 04-19-2007, 08:12 AM.
Re: stroking 2.8 v6
if you're interested in the aluminum head swap, do a search on Russel, as he did this swap (along w/the matching intakes) on a 3.4. Also keep in mind, NONE of the 3100/3400/3500 intakes make provisions for a dizzy. Best bet would be to aquire a 3.4 block (already set up for DIS) and swap everything over.
Just slapping on aluminum heads & going is NOT the answer, and will only frustrate you until you do the full research.
The 82~84 2.8 had the smaller mains than the 85+'s did.
iirc, :
3.1 is a bored 2.8
3.4 is a bored & stroked 2.8
**** I claim the right to have the bore & stroke switched on the above if it turns out to be the case ****1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
Re: stroking 2.8 v6
it wsa my understanding as well that the 3.1 is a stroked 2.8 and a 3.4 is a bored and stroked 2.8.
Yeah, i knew there was a small journal 2.8, but i wasnt exactly sure of what years.
a "dizzy" is a distributor. If you have one, and need one, that will need to be considered as the FWD heads and intake are all set up for the DIS systems.
oh, and if you are lookin for a 3.4.. i know where one is sitting.. but its in PA... are you anywhere close?Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
Re: stroking 2.8 v6
oh, one more thing.. there is a sticky at the top of this forum that has a ton of info about our motors. take a look. its long, but theres a lot of info.Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
Re: stroking 2.8 v6
Originally posted by 3.4 slow to goif you're interested in the aluminum head swap, do a search on Russel, as he did this swap (along w/the matching intakes) on a 3.4.
Originally posted by 3.4 slow to goJust slapping on aluminum heads & going is NOT the answer, and will only frustrate you until you do the full research.
Originally posted by 3.4 slow to go3.1 is a stroked 2.8
3.4 is a bored out 3.1
hybrid - \'\'hI-br&d - The offspring of a cross between species.
Co-Founder West Coast F-Bodies
West Coast F-Bodies Car Club - WCFB Message Board
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....3 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.4 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
