Cam Poll - FirebirdV6.com/CamaroV6.com Message Board
Cam Poll
  • Cam Poll
    OK, think I've narrowed it down to 3 possible Cams, all of which are ZZP. Either the VS Cam, GT1, or GT2. I've been through all this before and just want to recheck what everyone thinks about them. Here's the specs:
    VS: 206/216 at .050"
    Intake Lift .320" (.512" lift at 1.6:1 rocker ratio)
    Exhaust Lift .317" (.507" lift at 1.6:1 rocker ratio)
    115 LSA
    GT1: 210°/210° at .050"
    Intake Lift .317" (.507" lift at 1.6:1 rocker ratio)
    113 LSA
    GT2: 216°/216° at .050"
    111 Lobe Separation
    This is for a 97 Camaro, current mods are Cat-Back exhaust and CAI. Soon mods are LS1 rear with 3.73's or 3.42's, headers, cutout, and a cam (obviously). This is my DD, and it will be driven about 70 miles a day. Most of them are highway. I want to make it a fairly fast car, yet still keep the dependability and gas mileage (currently pulling out 21MPG redlining to every gear :D ). I'll be doing a springs and retainers swap to 105# when I install the cam. I'm not worried about the price of the install because me, my dad, and my friend who owns a race shop will be doing that.
    15
    VS
    0.00%
    0
    GT1
    20.00%
    3
    GT2
    46.67%
    7
    Other (Please State in your Post the name, specs, and include a link)
    33.33%
    5
    ~97 3.8L V6 Camaro~
    A few things
    Only Member of Team Hooker?!?
    Re: Cam Poll
    Abbott Racing Heads Naturally Aspirated cam
    -210/220 @ .050
    -.320" lobe lift on the intake, .512 with a 1.6 rocker ratio
    -.320 lobe lift on the exhaust, .512 with a 1.6 rocker ratio
    -112 lobe separation
    For great performance
    For better mileage the GT1 might be a better choice.
      Re: Cam Poll
      flip a coin b/t the GT1 or GT2...personally, I don't like the specs on that VS cam.
        Re: Cam Poll
        -210/220 @ .050
        Just a heads-up, that cam requires alot of tuning to get rid of the KR generated by it's harmonic. I know, I have that cam and have spent hours w/ a HPTuners trying to get it to run right. Once you get around that, it's good for mid-13s, 12s if you really start gutting the car
          Re: Cam Poll
          abbotts NA cam would be my choice
          http://www.bowtiev6.com/
            Re: Cam Poll
            True, I forgot about the problems you had with that. Good info.
              Re: Cam Poll
              That's something I forgot to mention. Preferably a cam I can run on a stock tune. I'm thinking maybe HP Tuners later this summer if I get more involved. I know the GT1 and VS cam both work fine on a stock tune. I want the car to be faster, but I'm not wanting to go so far that the dependability and quality is greatly questioned.
              ~97 3.8L V6 Camaro~
              A few things
                Re: Cam Poll
                Get HP tuners first. You will need it eventually anyway and it would allow you to get a better cam when you get to it. Some times you have to do things in an order you dont want to but in the long run it's better.
                  Re: Cam Poll
                  218/218 .528/.528 112
                  ^that cam on a '98 camaro was the cam-only record holder for a long time, and had virtually no tuning
                    Re: Cam Poll
                    Stattama Stage 4 Turbo Cam (Duration @ .050" is 224/218. Lift is .536/.528 with 1.6 rockers. Lobe separation is 116 degrees.)
                    abbott stage 3 heads
                    abbott ported intakes
                    130lb spring
                    titanium retainers
                    comp 7.00" pushrods
                    1.7 ratio comp cams pro magneseum roller rockers
                    OER lifters
                    http://s105.photobucket.com/albums/m...t=MOV00931.flv
                      Re: Cam Poll
                      Why would he want a turbo cam?
                        Re: Cam Poll
                        oh, i didnt read the question....i thought it was like a what cam do you have poll, ah well
                          Re: Cam Poll
                          I think the VS cam is more of a power adder cam than a na cam.
                          I have the gt2 and am happy with it. I've also heard good things
                          about the abbott cam mentioned above. I guess the gt1 would
                          be a good choice for you since you don't want to do any tuning.
                            Re: Cam Poll
                            CAM-361 - INTENSE™ Stage 1X Normally Aspirated Cam, duration @ .050": 212º/216º, lobe lifts: .327"/.321", valve lifts with 1.60:1 rocker arms: .523"/.514", lobe separation angle: 113º, intake centerline: 109º
                            That has always been my favorite N/A cam that no one has pushed to it's limites yet!
