does anybody on this fourm use this cam?
intense stage 1x cam
1998 camaro \"all slow no go\"<br />SpeedComp burlington nc<br /><a href=\"http://www.myspace.com/2supafly\" target=\"_blank\">www.myspace.com/2supafly</a><br /><a href=\"http://www.triadfbody.com\" target=\"_blank\">www.triadfbody.com</a><br /><a href=\"http://www.carolinafbodyclub.com\" target=\"_blank\">www.carolinafbodyclub.com</a><br /><a href=\"http://www.cardomain.com/id/esr98rs\" target=\"_blank\">http://www.cardomain.com/id/esr98rs</a>Tags: None
Re: intense stage 1x cam
I do not use the cam, but have owned one.
I don't know anyone off the top of my head that runs it in a camaro/firebird, but the cam has a LOT of potential.
The split duration and slightly wider LSA than most N/A cams (113 compared to 112) I think would make a major differance for power and if you wanted to add a s/c or nitrous down the road you could get away with keeping this cam. Also if you needed "bigger" without tearing into the engine again this cam would work well in conjunction with slightly higher ratio rockers.
I think this cam is commonly overlooked when people are shopping for a milder N/A cam that has a lot of potential.
thanks for the reply, my car will be done today and i cant wait to see what it does, i got this cam with the pushrods valve seals retainers timing chain, i also got the heads ported so i wonder if it will make ok power1998 camaro \"all slow no go\"<br />SpeedComp burlington nc<br /><a href=\"http://www.myspace.com/2supafly\" target=\"_blank\">www.myspace.com/2supafly</a><br /><a href=\"http://www.triadfbody.com\" target=\"_blank\">www.triadfbody.com</a><br /><a href=\"http://www.carolinafbodyclub.com\" target=\"_blank\">www.carolinafbodyclub.com</a><br /><a href=\"http://www.cardomain.com/id/esr98rs\" target=\"_blank\">http://www.cardomain.com/id/esr98rs</a>
