Would this stroker work? - FirebirdV6.com/CamaroV6.com Message Board
  • Would this stroker work?
    Could this work with our 3800 Series II Block?
    Buick 231 V6 4340 FORGED STROKER crank
    3.625" Stroker cranks
    The forged cranks have been a great sucess. There are some very fast cars now using the the stock stroke version with NO problems. Now we have a 3.625" STROKER version that will work with the forged rods we sell. We also have Diamond pistons for a complete rotating asembly. This crank is internal balance and requires the use of of an internal balance balancer and flexplate OR the stock units must be modified to internal balace specs.
    Item Specification:
    Application: Buick 231
    Stroke: 3.625"
    Rod Length: 5.960" or 6.00"
    CAT 4340 crankshafts incorporate these features:
    - Computer designed counterweight to reduce main bearing loads.
    - CNC machined to provide superior tolerance and journals micro polished to 5 RMS.
    - Generous 0.125" journal radii to disperse stress under high loads.
    - Each crankshaft has been visually inspected, X-rayed, magnafluxed, and ultrasonic tested to ensure perfection.
    - All cranks are heavier at counter weight for easier balancing with various applications.
    - Journal surfaces are treated with plasma gas nitrite to HRC60 hardness for superior wear resistance.
    SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
    Re: Would this stroker work?
    I don't think so. The only two stroker kits for our cars are the ZZP reworked kit and the COME Racing kit sold by Swann.
      I don't know of any reason or difference between the gn blocks and ours that would mean that kit wouldn't work. This is the one off ebay, right? I'm curious too, if anyone knows a diffrence between a gn block and ours.
        the GN blocks and ours are totally different engines. Therefore parts for that one will not work with ours. Look at zzperformance.com or 3800stroked.com for the stroker kits for our cars. Those are the only two that will work like T-punk said
        http://www.bowtiev6.com/
