I currently run 24#/hr injectors with a head/cam setup. I plan on stroking the motor with the zzp or C.O.M.E kit. If I do that and go to a larger cam will the 24lb/hr injectors still be good enough or should I bump to a 30 or 42?
injector sizing
Re: injector sizing
what kind of injector duty cycle are you hitting right now with the 24# ones in your car? Are you close to maxing them out?
Re: injector sizing
its hard to tell I suppose, I dont have autotap but I do have a fuel pressure gauge. With my 24#/hr injectors, the fuel pressure remains fairly constant throughout the entire rpm range however, I did notice a slight taper and drop close to redline. So I would say the injectors are pretty maxed outSLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
Re: injector sizing
First thing what everyone who is planning to get more power out of engine is to decide on tuning solution.
If ou plan to spend $$$$ on strocker kit you must have tuning solution in place before you go any further. There is no "hard to tell" or "I would say", there is no room for error, and autotap is not your friend.
your car with 24# and stock tune is not working correctly anyways.
Re: injector sizing
I dont ave a stock tune buddy. Its been fully tuned using HP TunersSLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
Re: injector sizing
do you own hptuners or did you do a mail order tune? Anything dealing with a stroker and such you are going to want your own hptuners, as a mail order tune is not going to cut it
Re: injector sizing
It was a mail order tune.
After the stroker I am gonna have to wait a while cause I cant afford HPtuners right now. A mail order tune will have to do for nowSLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...23 hours ago
