Hey guys, how much horsepower can a 3.4 hold if it had forged pistons and rods, with stock heads?
3.4 limit
Re: 3.4 limit
im confussed youve been a member since 05 but it doesnt seem like youve read anything. and your really kinda asking 2 questions the 3.4 bottom end with the addition of forged pistons(rods are already forged) will easily take 500hp, your not going to get there with the stock heads without a lot of boost or juice. if you truly want all the motor has to give swap to 3x00 heads get them p&p through in some forged pistons a cam and put a turbo on it then tune it with megasquirt.
edit: The strength of the heads is the least of your worries
Re: 3.4 limit
add in a FWD 3500 crank (factory forged) and you will be capable of handling even more power, this is what i live by, nothing is impossible with an engine it all depends how deep your pockets are, research and money are your best friends when building a high horsepower engine ;)
76 Camaro Rally Sport-355/TH350- Soon to be LT1/TH350 with a little laughing gas to wake it up...;)
89 Ram D350 CTD/M5- 1 Ton Dually getting 27 MPG's
Re: 3.4 limit
Originally posted by auto666im confussed youve been a member since 05 but it doesnt seem like youve read anything. and your really kinda asking 2 questions the 3.4 bottom end with the addition of forged pistons(rods are already forged) will easily take 500hp, your not going to get there with the stock heads without a lot of boost or juice. if you truly want all the motor has to give swap to 3x00 heads get them p&p through in some forged pistons a cam and put a turbo on it then tune it with megasquirt.
Another question how do you adjust the timing on a 3.4?Last edited by firebirdv6 3.4; 07-08-2007, 10:31 PM.3.4l 500hp to wheels <br />still dreaming
Re: 3.4 limit
you dont adjust timing on a 3.4
my 3.4 has handled 10 psi from a t70 on a stock tune...it can handle MUCH MUCH more if built rightBen<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
Re: 3.4 limit
Originally posted by White95you dont adjust timing on a 3.4
my 3.4 has handled 10 psi from a t70 on a stock tune...it can handle MUCH MUCH more if built right3.4l 500hp to wheels <br />still dreaming
Re: 3.4 limit
at the time i was using megasquirt to only control my 60 lb injectors. the timing was stock, which is why i didnt go over 10 psi. i'm working on a FAST system to take care of everything and then i'll just keep uping the boost every now and then until something breaks i plan to start at 15 and go from thereBen<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
