just want to know do u lose any torc when install 1.9 roller rockers thanks
roller rockers
roller rockers
2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainersTags: None
Re: roller rockers
well what if i dont want to move my hp and tq up in the power band i want my power band to be low rang not high so should i stick with the stockers then if i wanted that thanks2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
Re: roller rockers
Originally posted by Kal-Elwell what if i dont want to move my hp and tq up in the power band i want my power band to be low rang not high so should i stick with the stockers then if i wanted that thanks
Re: roller rockers
No matter what you do, be it cam, or rockers, you won't be able to make a lot of power with valvetrain upgrades without moving the powerband up. If you want more low end power you would be best off getting a stroker, but that is a hell of a lot more money.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
Re: roller rockers
lol no no towing here the reson i ask is i all ready have 1.9 rockers with ls6 spring and ls1 retainers but do to money issuses im going to take out the 1.9s and stick back my stockers on but im worried about the ls6 spring and ls1 retainer will they work with my stock rockers will i damage anything thanks2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
Re: roller rockers
Originally posted by Kal-Ellol no no towing here the reson i ask is i all ready have 1.9 rockers with ls6 spring and ls1 retainers but do to money issuses im going to take out the 1.9s and stick back my stockers on but im worried about the ls6 spring and ls1 retainer will they work with my stock rockers will i damage anything thanks
you are perfectly fine to switch back to stockers.
Re: roller rockers
cool thanks2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
