I was wondering why the GM 3800 V6 Xtreme Energy 255 HR12 Cam is more expensive than the INTENSE™ Normally Aspirated 3800 Camshafts, when the INTENSE Cam is a SS cam and the Xtreme From comp cam is only a mild cam?
A quick Cam Q?
Re: A quick Cam Q?
So Its not due to quality? I can get the intense for sheaper and get a greater HP gain for less, without having shoddy quality?1998 Red T-top V6 Camaro
- K&N Filter, Pacesetter Headders, MagnaFlow 2.5" Hi-Flo Cat, FlowMaster 80 Series, PowerDyne Supercharger@9Psi More 2 Come
Re: A quick Cam Q?
Originally posted by RyanAndyBobSo Its not due to quality? I can get the intense for sheaper and get a greater HP gain for less, without having shoddy quality?
im sure all of their different cams are of the same quality.
It is most likely cheaper because of the fact it is more popular and produced a lot more than the other cam
think about it, if you went and asked them to do a custom grind, its gonna be A LOT more expensive than one they have made thousands of.
Re: A quick Cam Q?
Yea bur being Comp Cams i'd figure theyd have quite a few in stock. Okay so I got another one for you. I Know ill need a douuble rooler timing chain, springs, rollers, etc.... but what about it "throwing my codes" Does anyone know if this cam throws codes or if i will "have" to get it tuned?1998 Red T-top V6 Camaro
Re: A quick Cam Q?
The HR12 cam is a pretty mild cam and can probably be run with stock heads etc.
As with any cam a tune would beneficial to get the most horsepower, however it probably will not be needed with the HR12 cam. I can't say 100% but looking at the specs it probably won't throw the p0300 multiple random misfire code.
Honestly if you're looking to upgrade the cam and still want it somewhat mild I would look at the, abbott racing heads cams, smaller Intense N/A Cams or the ZZP GT cams.
Abbott Racing charges the exact same price for ANY cam you order including custom grinds. Comp Cams grinds all the cams from the same cores.
Ken Abbott helped me with my custom grind for my stroker kit and it didn't cost any more than ordering a commonly produced grind.
Re: A quick Cam Q?
Thats pretty cool man. So the Intense stage 1 cam wont do any harm? im not lookin to run 13' or ne thing i just really like the sound and a little more pep in my step.Last edited by RyanAndyBob; 07-25-2007, 01:30 PM.1998 Red T-top V6 Camaro
Re: A quick Cam Q?
l36 182/192° 115° = -43° overlap
zzp gt1 210/210° 113° = -16° overlap won't set code
stattama s2 turbo 212/212° 113° = -14° overlap won't set code
intense s1x 212/216° 113° = -12° overlap will set intermittent code
zzp gt2 216/216° 111° = -6° overlap will set code
overlap = (intake duration + exhaust duration)/2 -2*LSA.
pick a cam with at least -14° overlap...or greater with heads/headers/etc. reduce exhaust duration with headers.
Re: A quick Cam Q?
You really should get a tune, even if you go with a little cam like the GT1.1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
